Yz250f oil level
4/26/2018 12:22 PM
Since there is no dipstick, should I just put in the recommended .73L (with filter change) and not worry about it as long as I change it frequently
Greg D.
2018 yz250f
4/26/2018 12:25 PM
Should I soak the filter first or is this what the increase oil volume is for?
Greg D.
2018 yz250f
4/26/2018 2:53 PM
You don’t have to soak the filter. It’s probably .65L without a filter change or something of that nature. Put the recommended amount in and change it regularly. Measure what you get out vs. what you put in. Should be pretty close. The bike will burn off whatever you overfill anyways. I tend to put a bit more than I need when I change oil to account for it sticking to the funnel or cup.
Does the bike have a sightglass?
4/26/2018 9:33 PM
Thanks for the response. Yes it has a sightglass.
Greg D.
2018 yz250f
4/28/2018 3:34 AM
I thinks its .76 qts with filter change. I usually put in 720-725 CC's with filter change. Always right in the middle of the sight glass...
2020 YZ450F
2018 KTM 450SXF FE
2016 YZ250F 2008 CRF450R
2015 YZ250F 2008 CRF250R
2001 CR250R
2010 YZ250 2012 CRF150R
2009 YZ125 2010 KX109.5
SSR Motorsports Dealer YCF Motorcycles
TAGMX Suspension & Graphics! www.tagmxsuspension.com https://www.liquidskinzdesign.com/
