Shelby, NC
Blackjack31
11/20/2020 6:42pm
11/20/2020 6:42pm
So I know there are 20 threads on this but I can’t find any that show a fix for this. Linkage slop where the knuckle bolts to the swingarm. There’s a lot of slop right now. I can put brand new bearings in linkage and upper shock and it will get a little better but still not gone or close to gone. Is there a fix? Can I order a new knuckle and it fix it? I tried new bolts and it might have helped a little but not really. So now I’m wondering, is my linkage knuckle messed up or is it my Swingarm?
You always should inspect the area that a bearing or seal is to sit in, for damage. Not everyone has things like internal bore measuring equipment, but a sensitive finger , if it can reach the bearings set point, can be quite useful to pick up on a subtle change in bore - damage doesn't have to be visual to cause a loose, floating bearing. And, indeed, some bearings require the compressive action of a suitably tight bore / landing to give correct clearances.
If visual and 'feeling it' inspections don't give you a quick answer, capmoto's suggestion is far cheaper than buying a new knuckle.
As a basic, slightly sweeping rule, if the bearings go in with the correct press fit, all the way to their final setting, well, the knuckle bore or whatever bore they are sitting in is, generally, OK.
You can find plenty of bikes in the showroom with 'slop'. I find it (very) 'disappointing', but it's the sad reality of things, at times.
Genuine bearings are nearly always the best thing to use, by the way.
A few accessory brands bearings / bushings / pins / spacers and seals, really are dreadful things.
Post a reply to: Yz250 linkage slop
