My 01 yz250 drips coolant when I pour it in and I start kicking it and when I get it started it like pours out but idk we're .. what can be causing this
Check to see if the coolant is coming out a small hole under the water pump on the engine side cover. If so then your water pump needs a rebuild. Also check your radiator cap as it may be worn out.
Check to see if the coolant is coming out a small hole under the water pump on the engine side cover. If so then your water...
We will be working on a YZ250 right after we finished installing the new tires, forged wheels and the brake job on the current truck project. A rebuild kit seems a better option for this bike.
Moisture-wicking fabric provides a soft, lightweight fit
Rebuild kits are somewhat cheap.
Post a reply to: Yz250 coolant leak
