Hello Vital MX Visitor,
We’re conducting a survey and would appreciate your input. Your answers will help Vital and the MX industry better understand what consumers like you want. Survey results will be used to recognize top brands. Make your voice heard!
Five lucky people will be selected at random to win a Vital MX t-shirt.
Thanks in advance,
The Vital MX Crew
DO NOT use a sleeve in your YZ125...many of the YZ's crack there bc they make it very thin to get more exh clearance and window opening, it helps power. They can actually weld more meat on there so it doesn't crack again...that is the thinnest and the hottest part of the cyl and it bulges into the cyl when super hot.
Call and ask for Chris, he can get it done for you. Also send in, (or buy from them), a replacement piston so they can finish hone it to clearance the bore. Ask them if they need any power valve stuff to make sure it clears any slag build up to.
Good luck-
I realize there is a cost and time saving to go that way, but its well worth waiting for replate.
re plate is 200-250.00
125.00 ish for a sleeve labor to install 200-300.00
Post a reply to: Yz125 Cylinder Sleeve
