Yz 250 engine extra part?
3/1/2020 11:14 AM
Edited Date/Time: 3/1/2020 11:15 AM
Tore the motor apart a month ago, got everything i need to put it back together, and looking at this part, cant figure out where it goes or even if it is part of the engine, may have placed on my bench randomly. Od 31mm, id 19mm, width 15mm.
Its not the sprocket bushing, got that.
So is this a yz250 engine part? Been through fiche multiple times
3/1/2020 11:33 AM
Edited Date/Time: 3/1/2020 11:34 AM
3/1/2020 11:34 AM
Don’t know the year of your engine but that looks like the collar that sits between the primary gear and the main bearing on the early 2000 models
3/1/2020 11:48 AM
Edited Date/Time: 3/1/2020 11:54 AM
2001 motor, looking at the fiche which part?
3/1/2020 12:16 PM
Edited Date/Time: 3/1/2020 12:34 PM
It should be under the clutch Fiche... look at 2000 model and a 2001 model you should notice a difference 2000 utilizes a collar like the one in the photo; 01 utilizes a Thin splined thrust washer... easiest way You would be able to verify is look at the old crank if it has a long spline on the primary side it uses the longer collar a short spline uses the smaller one...
3/1/2020 1:15 PM
Edited Date/Time: 3/1/2020 1:17 PM
Great, thanks for the help, crank was thrown away last month, guess it was a 00 vice 01 enginesmile, i put a newer year crank back in so i will just need to get that thiner slpined thrust washer. Really appreciate you repling.
Best regards!
3/8/2020 11:36 AM
Kijen- can you pm me your contact info? I’m in fl too & interested in some of your parts for sale.
Thanks
