YZF250 KYB-Suspension
3/26/2018 7:10 AM
Hi!
Bike: Yamaha YZF250 BJ.2017
i wanna change the spring of my KYB-Fork. The only Question i have is, should i screw the pressure and rebound in or out(Soft-Hard) before the rebuild?
Thanks
3/27/2018 10:39 AM
Only doing a spring change??? I believe the answer is no. If you were changing fork oil, then I believe the answer is yes.
Here's how to change them without messing with the oil
3/28/2018 2:56 AM
Yea you should back out all your clickers. You have to change the oil to do springs. You cant seperate the forks without draining oil.
3/28/2018 6:34 AM
SimonDob wrote:
Hi!
Thanks
You are gonna want it on level 69 so that it is easy to swap out.
