YZ 125 Fork Guard Conversion
6/9/2018 6:35 AM
Edited Date/Time: 6/9/2018 9:40 AM
I'm in the process of building a 2003 YZ 125 and I'm wanting to convert the fork guards from the older style (have clamps around the forks) to the newer style with no plastic clamps around the fork leg. I lined up fork guards from a 2017 YZ250F and they are way off.
Has anyone ever done this conversion on an 02-04 YZ125 or YZ250?
6/9/2018 11:33 AM
Sometime between 2006 and 2014 the fork lugs were changed. It is possible but unlikely the older (2006-?) fork guards will fit.
6/9/2018 12:20 PM
chillrich wrote:
Sometime between 2006 and 2014 the fork lugs were changed. It is possible but unlikely the older (2006-?) fork guards will ...more
Thanks. The lugs are definitely a different shape, but I saw a few other YZ's on here with the style I'm looking for. I wish Cycra or UFO would make an updated fork guard for the older generation YZ's.
6/9/2018 2:22 PM
DaBaum44 wrote:
Thanks. The lugs are definitely a different shape, but I saw a few other YZ's on here with the style I'm looking for. I wish ...more
That would be so nice
2017 RMZ450
2005 YZ250-sold :,(
1998 YZ250
2005 KX250F
IG @2HRacing
6/9/2018 2:56 PM
Edited Date/Time: 6/9/2018 2:58 PM
As I recall, the guards are stiff enough that you don't need the guides clamped on the legs. People used to just remove them back in the day. I'd be more worried about that brake hose not being secured to the guard. When doing the CR routing conversion like that I think guys used to cut those 2 hoops off and then there was an aftermarket clamp to hold the hose to the guard.
Check this. Litespeed used to make guards to eliminate the clamps and do the brake conversion.
https://www.vitalmx.com/forums/Moto-Related,20/03-YZ-Lightspeed-Fork-Guards-Advice,1295202
Powerband in every gear !
6/9/2018 3:04 PM
Edited Date/Time: 6/9/2018 3:15 PM
For your 2017 guards you will need 2008+ fork lugs. That is when they changed to that bolt pattern. I had a 2005 and even it was a different pattern from the 03 you are showing. The 05-08 is bolt on side one bolt 90 degrees from that one on the front, and another one 90 from that one on the other side of the fork guard. Pain to reach that last bolt.
The 08+ went to one on the side then one about 45 degree around, and another 45 degree where you can reach it from the front of the guard.
If the lower fork tube is same dia. And thread then you could change the fork lugs. But that may also mean new axle dia. Which would mean a new hub. Your brake caliper should work with the new lug but in 08 they came with a lighter and stronger caliper, you could also fit a Honda caliper for super strong brakes!
6/9/2018 3:23 PM
FGR01 wrote:
As I recall, the guards are stiff enough that you don't need the guides clamped on the legs. People used to just remove them ...more
Might have to research the clamp you mentioned, otherwise I'll use the stock style. If Lightspeed had those fork guards in blue or black I'd be all over it.
6/9/2018 6:25 PM
More info here including the Ride Engineering clamp at the bottom.
https://thumpertalk.com/forums/topic/795717-06-front-brake-line-fits-02-yz250/
6/10/2018 8:26 AM
Why not just do the sss fork swap if you are really serious about wanting new style. I just did a 2015 conversion and bought the same year fork guards as the bike and literally no one notices.
6/10/2018 1:37 PM
...more
Great info! Thanks
6/10/2018 1:40 PM
Edited Date/Time: 6/10/2018 1:42 PM
Alec138 wrote:
Why not just do the sss fork swap if you are really serious about wanting new style. I just did a 2015 conversion and bought ...more
I haven't ridden the bike enough to justify a fork swap. Just wanted to improve the looks while I'm doing graphics. That is a good idea though, and I'll keep that in mind. Did you have to swap wheel sets, axles, or clamps for the conversion?
6/11/2018 2:16 PM
DaBaum44 wrote:
I haven't ridden the bike enough to justify a fork swap. Just wanted to improve the looks while I'm doing graphics. That is a ...more
Yeah you have to do the wheel/axle too since your bike is older you may need triples as well? If you are serious look for 06+ yz parts bikes. I bought the whole front end off a guy on craigslist to use as a backup set of forks. All bearings are shot but he sold me wheel, steering stem, triples top and bottom, forks for like $300. I have a 10’ yz btw.
6/13/2018 3:32 PM
The fork guards are stiff enough, for sure. They will eventually rub holes in your dust seals if you don't run the plastic guides, however. (Not enough to make the seal fail, but enough that you'll notice it when washing the bike!)
I used to cut one of the hoops off completely, then trim the other one so it was like a bracket sticking up from the fork guard. Then drilled two holes and used the hose clamp from the bottom of the fork leg with some nylock nuts on the screws to secure the hose to the fork guard.
Braaapin' aint easy.
