Annapolis, MD
8/27/2021 2:47pm
Hey all so just got the PHDS mounts to run on the Rocs clamps. I notice that the bar pad I run (2.0 square) for my Pro Taper Evo’s don’t come close to fitting over the PHDS. I have the fixed clamp system too, they were a stretch but could at least connect the Velcro to secure the Pad to the mount. Has anyone else had these issues with the PHDS clamps and the Pt Pad? If so, know any tips or hacks that you think I might find helpful? Thanks in advance!
If you’re after a dampening bar mount try the Flex-fix system - they work just as well as the PHDS, are lighter and you can run an Evo/contour/fatbar style bar and pad with no problems fitting through pad.
I used a 1 inch sanding wheel and just relieved rhe inside of thr pad foam and it worked great.
Post a reply to: Xtrig PHDS Bar Mount + Bar Pad fitment Issues?
