- Pick trends
- Create a private league
- And more!
Edit- not to sound like a jerk, curious as I may be getting a mid 80s bike.
My suspension supplier told me he can take the shoch body back to stock for $175 plus labor.
http://www.fcrsuspension.com
this is an evo bike. The shock is 20+ years old. The plan is to
collect the best spare parts I can find, or recondition old parts to
new oem specs. I like the bike enough to make it the bike Ill ride
most often. Its mx use only so I like everything to be in good shape,
if I was riding single track or something Id probably slap any old
ebay part on there. Planning on getting back into racing on it as
well. Plus its a fun project trying to get things as new as possible.
Most any shock from the 90's is going to be anodized from the factory. I know even 1989 and newer KDX shock bodies were anodized. If it was not used with low oil, then the body may be just fine.
I will say this, if it is scratched, cost effectively it is trash. Buy a used one off eBay and take a chance.
Look for ...
Technical Touch rebuild kit 129994600201
"Is it possible to rework the internal bore of a shock that is at,near, or beyond its oem service limit, by using either anodizing, or some other hard coating, to return it to like new oem bore spec?"
So if your shock body has worn out the anodize but not into the aluminum, it is possible to preform the above process to renew the anodize thickness and make it like new again. But you need to use someone who knows what they're doing and the process is pretty pricey. You'll likely be better off finding a used shock on eBay.
Post a reply to: Worn shock bodies, repair options?
