My kx250f doesn’t want to start it will only start if you push start it but not by kicking it the timing is right and the mechanic said it had little compression what should I do?
Likely valves. Service manual is a must for all, for sure take a few bucks to invest in one.
When the mechanic was looking at your bike, do you have more details to share other then some one said the bike had low compression?
The mechanic also told me to buy a new cylinder and piston but idk if I should do that before checking the valves bike also has some holes in magneto and is overheating and coolent is coming out of the overflow.
Richard Aira wrote:The mechanic also told me to buy a new cylinder and piston but idk if I should do that before checking the valves bike also ...more
Sounds like a blown head gasket?
#1
KX125
my best friend has a 04 , valve probs since he got it .. i raced it once in 06 on its third motor ... dropped a valve on a 100 footer ... i was laid up for months ... needless to say ... if it starts by push starting it turn to the valves first ... the 04 and 05 has soft valve seats and is probably the most un reliable motocross bike ever made ... they were just problem riddled bikes man ...
sorry!
2018 crf 250r
Sounds like you should sell it and get a better bike. By the time you get a cylinder and piston kit youre at $500. Nevermind the other stuff.
Low compression can be leaky valves, leaky gaskets, or a worn piston, even a gouge in the cylinder.
Leaky valves mean you need the head reworked - new valve seats, valve guides, seals, valves themsevles. Thats big money. At least $400.
Mind you these prices are without paying someone to do it for you.
2009 Kawasaki KX450F
2009 Kawasaki KX250F
2002 Suzuki GSXR 600
