- Pick trends
- Create a private league
- And more!
I’m going to see if I can find out what kind of exhaust I ended up buying (thinking it was oem)
I’ve also ran aftermarket ignitions on 450’s with a noticeable improvement over the oem’s..
I’ve narrowed it down to two tuners in SoCal or PR2 for the engine work. It’s not likely I’ll find a JD ignition so I’m thinking zeeltronic, unless you guys can recommend any other companies that still make them?
I really wanted to use PR2, but after a bit of reading, his mods will likely wear me out. As much as I want the high peak horsepower numbers, it’s more logical for me to aim for more low end/mid. Top end/overrev is a big deal for me though, so I still want some of that. My 250sx never signed off up top, I could hold it in 4th instead of shifting to 5th if I had a turn coming up soon. In stock form that bike fell on its face up top. This bike would mostly be ridden in SoCal deserts and the NGPC series with the occasional Glen Helen Saturday
However, the PC engine is probably the best value in terms of performance gain per dollar spent.
I’ve changed my mind multiple times already so when I finally make a decision I’ll give an update lol
Would not hesitate to use him again.
This is what I found when I pulled the cylinder. Can this be fixed? Damn 15 year old kid
What did you end up doing? Did you choose anyone yet?
I sent it out to PR2 yesterday. He said the hacksaw port job shouldn’t be an issue. I was going to go with Tom until I decided the cylinder needed to be plated anyways. I also got a new oem cylinder delivered yesterday so I’m not sure who that will get sent to, I’d really like to send it to PC but they can’t put me on the phone with anyone that is actually somewhat knowledgeable which is scary to me. I still want to use TMR based on his customer service alone. He was up and texting me at 5am and kept very good contact with me throughout the day.
I bounced a few questions about a 125 off of him and was surprised he had an option for everything.
Also when you get your motor back it comes with a full set up sheet. Recommended gearing, plug, plug gap, jetting chart for temp and elevation, recommend oils, pipe etc etc.
He is one of the best easily.
Keep in mind, he probably won't build you something 54hp stock bore. He tends to keep his engines rideable and less peaky. Maybe he already told you that.
You should make a build thread.
Post a reply to: Who builds the fastest 03-04 CR250r engine?
