Denver, CO
Couple questions. I am building some wheels and I have done it before but not much. I am struggling with the final bit. I put it together and tried my best to turn all equally and had some tension on the spokes and it was pretty straight. Then I went though and did my 3 laps of the wheel getting all the spokes to 25in lb then to 30 in lb. I worked the wheel a tad to get it pretty straight. Then trying to go to 40 in lb. I just can’t. Once I try to fix the little wobbles some spokes are not as tight as others. Then when I go around with the torque wrench to get them all the same it pulls the rim out of line again. I can get it straight when not all the spokes are same torque but getting them all the same torque and straight is not easy for me. Any tips
From what I would think you would have to do every nipple the same amount of turns every time tightening every spoke at the same rate. If it’s out of true you have to start over.
Because simplifying it down think about your bar clamp top caps. Tighten one down to torque then the other down and the cap is leaning way to the first bolt. Then you have to loosen all the way up and straighten them and then tighten if you wanted the gaps to be even. Same thing for a wheel just on a way bigger scale.
But it has to be possible or they would not sell 100 dollar spoke wrenches. So somebody has to know where I’m going wrong
Again, this is why I don't use a torque wrench. Because it will have you chasing something that is not always attainable. At the end of the day, if the wheel is true and the spokes are all "pretty damn close" in tension, you are good to go.
What I ended up doing was to tighten all the nipples by hand and once I got to the point of needing a wrench I'd turn every spoke 1/4 turn and do a few laps, adjust the straightness where or if needed then did a few more laps at 1/4 turn. I did that until all the spokes were torqued to 48in. lbs. and the wheel was still straight.
Someone sneak a camera into Dubya and give us the secrets! hahaha
Also, it seems a torque wrench is kind of worthless after the initial build what with crud getting in there and throwing a true reading off, right?
BTW man, nice frigging Camaro!! Holy crap, that's some work!!
I would choose to prioritise trueness.
Thank you, someday it will run lol.
Post a reply to: Wheel building
