Going over the bike today and noticed there was a bit of play in both the front and rear wheels of my 18 YZ125.
Anyone know the bearing sizes for both wheels?
Plan to get the bearings through my place of work at a considerable discount.
Make sure to toss the unsealed fronts for some proper sealed bearings; Can't believe the YZ's still come like that from the factory...Very common problem
Front wheel bearing: 6904
Front wheel seal: 26/38/7
Rear wheel bearing: 60/22 2RS
Rear wheel seal: 30/44/5
Rear wheel bearing: 62/22 2RS
Rear wheel seal: 30/50/7
None of those do you any good unless you replace the seal collars at the same time. Even the tiniest groove will cause your new seals to leak, let moisture in and shorten the bearing life.
Re-grease the seals every time you take the wheel off, or at least every couple of rides.
People who aren't careful with their pressure washers can kill the seals & bearings real quick.
The Pivot Works kit comes with some very nice collars that have an internal o-ring. I use those, but their kits use Chinese bearings to keep the price low...
Post a reply to: Wheel bearing size, YZ125
