Whats the best way to lower the seat?
5/12/2018 12:28 PM
Who has done it? I dont want to ruin it and it should be as clean as possible
5/12/2018 3:12 PM
I’ve taken off the cover and cut the foam with a turkey cutting knife then smooth the edges using a hand grinder with sanding wheel on it.
5/13/2018 1:30 AM
CarlinoJoeVideo wrote:
I’ve taken off the cover and cut the foam with a turkey cutting knife then smooth the edges using a hand grinder with sanding ...more
Is it hard to put the cover on again?
5/13/2018 7:34 AM
Edited Date/Time: 5/13/2018 7:34 AM
Here’s a video about how to install one.
https://m.vitalmx.com/videos/member/Untitled,12317/ML512,13480
5/13/2018 10:11 AM
Electric turkey knife is the way to go. Take a little off at a time, very easy to take too much off then your screwed.
We are the sum of a 1,000 lives. What we know is almost nothing at all.
5/16/2018 9:46 AM
What the above posters have said is correct. You can use a electric knife and cut it down to your specified height. If you are uncomfortable doing it yourself, this is a service we do offer.
