Looking to replace the intake boot on my 2002 cr250. It seems that they are discontinued. I can get one for a 2005-2007 model cr250 but they had a shorter carb and Im thinking that the intake boot would be too long, or even at a different angle and even if it did fit onto the carb ok would it fit my stock reed cage OK? Any help would be greatly appreciated. I am trying to install a keihan pwk carb and boyesen rad valve. I thought the rad valve would come with its own intake boot, but for my particular model it does not instead it says to use the stock intake boot, so my replacement intake boot must match up to the stock reed block design or it wont work with my already purchased rad valve. The pwk carb is the long body airstriker without the tps.
