What is the best way to fix this?
4/27/2020 2:42 PM
Does it need cut off and a new piece made and welded on? Can I fill it with weld and grind it smooth? Would using a brazing rod instead of weld be a bad idea? Is it fine as is? It’s not wore through yet. How would you guys fix it?
4/27/2020 3:23 PM
Aluminum, bring to aluminum welder. Then replace chain buffer before it happens again.
4/28/2020 4:01 PM
I would check eBay for one.
4/28/2020 9:29 PM
as long as it is not in the bore...a welder can fill it up ...watching the heat...file down ...sand...and your good
4/29/2020 4:40 AM
If you have it welded be sure the welder understands that the bore is a bearing press and cannot change size. If the bearing has to much when the welding is done it will prematurely wear or not rotate smoothly.
4/29/2020 4:42 PM
Have the welder preheat the swingarm to 300 degrees F and fill the slots. easy repair.
