What clutch are you guys using
spimx
Port Isabel, TX US
My 18 kx450 is needing a new clutch. Just curious what you guys have tried and what yall like? Thanks in advance
Bogett287
Malone, NY US
9/25/2021 3:56pm
Rekluse torque drive pack way better then stock works really good
Yeti831
UT US
9/25/2021 5:38pm
I’m a Hinson guy personally.
I got the wrong basket for my Honda so just running their fibers and springs, that alone was a great improvement.
9/25/2021 7:40pm
Hinson here too. Have heard good of the rekluse also. Just always had Hinson and haven’t had issues to I keep using them in all my bikes.
Rider 5280
Denver Metro, CO US
9/25/2021 10:28pm Edited Date/Time 9/26/2021 12:28am
I've really been liking the Wiseco forged clutch baskets with lifetime warranty paired with Rekluse Core EXP 3.0s as well as Radius CXs. Great overall feel and durability.
Note:
You can readily convert a Radius CX to a Torque Drive, too, by rotating the pressure plate ring down and out of the way. Just need a few extra clutch frictions and steels when to backfill the EXP disc. Best of both worlds. I love this versatility. Rekluse can tell you what extra parts you need for your specific bike.
murph783
CT US
9/26/2021 7:02am
I mean it depends on the bike. I’ve been a Yamaha guy for a good long time, and their oem stuff is great so I don’t feel the need to look elsewhere.
Last time I rode a Kawi was ‘09 but those things were trash so I went to Hinson. But honestly I only really see the benefit in changing if you go full bore-basket, pressure plate, their plates and fibers, springs. Just get the whole ensemble. But it’s not cheap that way.
If stock worked well, keep it stock
Rickyisms
FL US
9/27/2021 7:11pm
I replaced my stock KTM system with a full Hinson. I use DP plates now which I’ve had great luck with (Better life and similar performance as Hinson plates). DP plates definitely run cheaper than other companies as well.
Coughlin639
Clayton, NY US
9/28/2021 11:27pm
Rekluse Radius CX here too. The steel sleeves for the plates to ride on instead of damaging the basket is ingenious, the auto clutch is nice insurance, especially when you're on a Suzuki that you've gotta kick start, and it's acts just like a normal clutch. I've had several people ride the bike that never knew it had the clutch in it. 38 hours on it and the plates are still in fantastic shape
Moto520
Schaumburg, IL US
9/29/2021 7:47am
Rekluse Torque Drive if i can afford it at the time. Otherwise.....stock has always worked well for me with all bike brands. I'll get a couple of either Pro Circuit or Hinson springs to tighten things up over stock.
Sandusky26
Eastern, NC US
9/29/2021 9:56am
How much of a difference is the torque drive clutch pack on a 450. Id like to try it.
Moto520
Schaumburg, IL US
9/29/2021 6:27pm
Not a huge difference but decent enough to consider. The actuation window is larger so it’s easier to fine tune use of the clutch. You can feed out the clutch more precisely. It’s less off and on
Post a reply to: What clutch are you guys using
