Lake Havasu City, AZ
4/12/2022 8:13am
Does anyone definitively know if the new WP 8950 SuperTrax has a variant compatable with older chassis Husky’s (2017)?
I’ve spoken to FC, AEO, Racetech, and others. All give wildly different answers to this question.
And WP themselves dont know because they dont check for backwards compatibility.
Thanks.
Thanks.
Apparently quite a few WP dealers have installed this shock on older bikes. Based on their sales records. But Im having trouble getting ahold of the specific techs that did it. Likely they sold it to a customer and the customer figured out a way to massage it.
WP will not comment on it directly to me.
Due to the frame change in 2019, there are some changes that result in two things...
1. The shock (just above the preload threads) is going to be up against the air boot.
2. The new reservoir angle will require a small cutaway of the side panel plastics. (Common with current GasGas bikes running this suspension)
My questions are these...
A.... Is the new supertrax shock body diameter different than 7750 trax shock and so it rubs harder on the airboot?
B.... Arent the GasGas bikes running the older chassis? If the 8950 can fit on them, why not my older Husky?
Or does the Husky have significantly different airboot routing?
He says they have installed the 8950’s on the older bikes. But variables must be accounted for.
He said touching of the airboot is normal. They put some clear fork decal over that area of the shock just to protect from dirt/sand wear of the aluminum.
He said major concern was taking into account the existing setup. Said sometimes thicker bumpers are necessary for lowered bikes. Such as mine with the Pro Circuit linkage. That affects the stroke and if not accounted for he’s seen bikes with holes in the carbon sub frame from the rear tire punching through.
But as far as geometry of the shock, it’s only the reservoir angle that is significantly different according to Evan.
He didnt know off the top of his head which variant of this shock would be right for me. The ‘21 Husky version for the lowered OE chassis’ might help or hurt in my case.
Also, fwiw, the current GasGas bikes have the 2019 chassis. Their only issue with this shock is the plastics needing a small cutaway due to the reservoir angle.
Post a reply to: WP Supertrax compatibility
