Tampa, FL
Hey guys - first time owner of a bike with air forks.
I'm trying to find the correct PSI to set my front fork at. I weigh around 210-215 with all my gear on.
I had one suspension guy say around 155 PSI, while another said around 170 PSI.
I just wanted to get some opinions on here to see which end of that range i should start at? I'm a C class rider on a 2018 KTM 250 SX-F.
Thanks for the help.
For instance, if the zip tie is bottoming out - couldn't be that my air pressure is correct but my compression is too soft?
If that's the case, how i would i know?
This is my first set of AERs, as I had an ohlins spring kit before, but I have been honestly surprised with how well I’ve gotten them working. The most important thing you can do is get your sag set as that will really impact how well the bike corners and if it’s off, can make you think the forks suck ass when in reality, the shock is off.
Best of luck!
I'm guessing you should be somewhere in the 160-170psi range since you are heavier than me but my Alta MXR is heavier than your 250f.
One thing to remember. You shouldnt really be messing with your air pressure too much. The AER48 has lots of compression and rebound adjustment in the clickers. And i've found the AER48 works best with higher pressures and a little less compression damping. Also, make sure your fork can rebound fast enough. I've found a lot of the harshness issues i used to have with this fork were simply because it had too much rebound damping and fork was falling too deep in the stroke in rough stuff, and packing up. I typically speed up the rebound (more clicks out) until the fork starts to pogo, and then slow the rebound down a little from there (go back in a few clicks). The softest part of this fork is at full extension, so the key is to let it extend fast, without sacrificing cornering ability. Too much rebound damping will let the fork dive and the bike will oversteer. Too little and the front will understeer. Its all a balancing act.
Post a reply to: WP AER 48 Forks - What's the correct pressure for my weight?
