Vital Question For Vital Mechs
3/5/2018 2:41 PM
My 2015 Yamaha is leaking fuel out the carb overflow when the fuel is on. I'm sure it is the needle and seat. I see the needle for sale on the schematic, but does that include the needle seat?
3/5/2018 2:53 PM
I would make sure your seat is sealing before you go replacing it. If it seals then you just need to adjust your float height
3/5/2018 2:53 PM
Edited Date/Time: 3/5/2018 2:55 PM
yz125? yz250?
If it's a YZ250, looking at the parts fiche it's just the needle. The seat doesn't look to be sold separately
If it's a 125 then yes it is sold as a set
2017 RMZ450
2005 YZ250-sold :,(
1998 YZ250
2005 KX250F
IG @2HRacing
3/5/2018 3:25 PM
if its a keihin then youre not gonna be able to replace the seat. Mikunis you can do both.
I would air check the needle to ensure its wrong first and possibly adjust float height to remedy the leak.
did this leak happen suddenly or after sitting for a long time?
3/5/2018 3:53 PM
Thanks guys. It has been sitting for a bit. It's a smoker 250 with the Keihin carb.
3/5/2018 4:02 PM
Give this a look... hope this helps.
https://www.jetsrus.com/carburetor/carb_keihin_PWK33-41_carb_exploded_view_parts.html
3/5/2018 5:17 PM
In almost 40 years as a MC mechanic I typically only needed to clean debris out of the carb and seldom had to replaced parts.
3/5/2018 6:26 PM
Tap the body of the carb with blunt end of a screwdriver and see if it stops
3/5/2018 7:12 PM
Has the bike been sitting for a while?
3/5/2018 7:13 PM
Check to make sure there's not a styrofoam peanut stuck in the float bowl.
3/6/2018 4:51 PM
Damn you Slippy! smile
