Austin, TX
Is there a way, or tool that can verify the hours on a KTM 450? For example, Yamaha can be done via the new wifi app, Suzuki can be done with the service LED. Any ideas on the KTM? The bike I am interested in has an hour meter, but not sure 100% I trust that...
So, as WEAL says, the ECU should tell all. Is that a KTM service department tool only? Or is there there other ways?
Thanks!
Earlier models, yeah you have to read the ECU
The bike looks immaculate, is priced very good, and truly has very little wear.
On all my KTMs the rear upper shock body is slightly rubbing on the inner side of the air hose between filter and injector, the amount/absence of wear on the hose is a solid indicator of the hours this bike was ridden.
The front and rear chain guide will tell as well how many hours they were in use.
Generally - if you like what you see and the vendor seems trustworthy and not telling a lot of shit, allows you enough time to inspect the bike thoroughly and your gut feeling is "yeah, I want it!" - then go for it. The bikes are really good, I did 165 hours on my 16 SXF 450 without any engine problem.
Post a reply to: Verify hours on KTM 450SX-F?
