Throw ur specs for 2013 ktm 250sx - do it for tha boys
hyler199
9/8/2017 4:43pm
250sx all stock 50:1 premix, fmf gnarly pipe stock muffler
I live in Toronto so elevation sealevel
So far I tried
1. br8 plug, 42 pilot, 155 main, stock needle 3rd clip, air screw to taste ---- result : rich af, boggy down low rips up top
2. br8 plug, 40 pilot, 155 main, necj 3rd clip, airfuel screw to taste ---- result: plug still a bit too dark but not oily
3. br8 plug, 40 pilot, 155 main, necj 2nd clip, airfuel screw to taste ---- result: plug burned real clean, too clean looks a bit lean. only ran for about 30 minutes hammering down
RCF
PA US
9/8/2017 5:22pm
You need to go up on the main to at least 170 with necj
hyler199
9/8/2017 6:59pm
What plug, pilot and needle position do you recommend? Why the 170 at sea level? thx for your suggestion
RCF
PA US
9/9/2017 8:55am Edited Date/Time 9/9/2017 8:58am
Necj is leaner than the stock KTM needles we run a 40 or 42 pilot with that needle third clip. We ride at Field of Dreams in Jersey a lot which is at sea level bike runs great. If you like to scream the bike I go even a little higher to a 172 on the main. That needle makes the KTM run a lot cleaner on the bottom I could never get the jetting right with the stock needle. We always use br8ecm for the plug.
stone881
Fruita, CO US
9/9/2017 9:02am
I had a 2013 and was running a billet APT Smartcarb on it, I did have to trim the air boot connector. Cleanest running 2 stroke I have ever owned and made really good usable power imo, maybe just a bit soft off the bottom. I know that a lot of guys have also had success w Lectron.
Don't have a smoker any more, so was gonna put the Smartcarb up for sale, if anyone is interested.
hyler199
9/9/2017 10:46pm
RCF wrote:
Necj is leaner than the stock KTM needles we run a 40 or 42 pilot with that needle third clip. We ride at Field of Dreams...
thanks for the imput will check it out on Tuesday when i have the time!! open to more suggestions aswell!!
Post a reply to: Throw ur specs for 2013 ktm 250sx - do it for tha boys
