- Pick trends
- Create a private league
- And more!
Go to Ace hardware & purchase the 8mm tap you need. When you need another tap, purchase it too. Mostly there are three taps you need. 6-8-10mm. Sometimes 4 for those pesky euro bikes.
No need to buy a set that for the most part, you will never use three quarters of them.
The 16 is 16mm long from the end of the bolt to the bottom of the head.
Above are direct answers to your question, but i highly highly recommend you learn about hardware if youre working on stuff.
a standard tap may not work for you in a blind hole because the end of the tap is tapered and wont cut a full thread. A bottom tap does just that. It taps to the bottom of a blind hole.
Grainger is an industrial supply website that has all that kind of stuff.
That said, you dont need a full set just for dirt bikes.
https://www.acehardware.com/departments/tools/hand-tools/taps-and-dies/…
Most bikes I have worked on takes a 6x1.0 Yes, I have a new husky, but never paid attention to sizes of bolts. Yet!
And yes a bottoming tap would be best in your case.
If in doubt, take the bolt to Ace and ask for a tap to fit. Remember they are the helpful peeps!
What is the bolt holding on??
Post a reply to: Tap and die set for bikes?
