CT
So I’m gonna give VPR a shot in my 2020 YZ450, it says clearly on it do not store in vehicle, drain carb after use. I remember having to do that back in the day with U4 in carb bikes, but what’s the deal with newer stuff? The dealer said he just leaves it in his tank without issue, but I want some more opinions from the vital brain trust
I think those disclaimers are carry over from when fuel had reactives in
It is an oxygenated fuel. If you are jetted / mapped appropriately, and the fuel sits exposed to ambient you will have a rich condition with the oxy depleted fuel.
If you're just pouring T2 into your bike, and you arent like +2 sizes on the main, then you're lean with fresh fuel and probably good with the stale stuff.
Not sure why some would spend money on 5 gal pales of race fuel and not map/jet appropriately. C12 to T2 in a tom morgan yz250 was +2 on the main.
The spec sheet shows oxy content and the stoich for the fuel, both VPR and T2 / T4 are a fair amount below 14.7 so really marketing them as a "pour in" replacement is silly.
We either drain the fuel out of the bowl and tank and then add a half gallon of pump/C10 or T4 and run the bike for a few minutes. Or for the last ride of the day we simply fill the bike with a non reactive fuel like T4 or pump/C10.
Generally, if the fuel smells like you just entered the Supercross arena on Saturday, then it should be drained after use at some point. T4/C10/C12/110 fuels do not have those reactive compounds so no need to drain after use.
Post a reply to: Switching fuels to VPR -storage?
