Queensland
Hi All, Does anyone have any recommendations for suspension set-up on soft sand at speed? I have an event coming up with average speeds of 60mph up to 130mph in coarse loose sand, it does get a bit whoopy in parts.
In the past I have run the rear with 110 sag 10 clicks out on compression and 3 clicks out on rebound.
Front I run the fork flush with the top of the triple clamp, preload adjuster +6 compression 5 out, rebound 5 out.
2019 Husky FE501
The bikes do get snakey after 60mph
Thanks
2019 Husky FE501
Thanks
If you get sideways in high speed, you dont want rebound to return as soon as wheel touch ground since it might spring you sideways. Some margin on that.
It wont get wobbly due to lack of some rebound, but it will get harsch but that just means you can slow down some in those few places. Chassi also gets lower with slower rebound, which leads to better stability.
In short, with those speeds, I would take stability and safety over comfort. So slower/stiffer rebound, stiffer comp.
Post a reply to: Suspension set-up for high speed soft coarse sand
