Okeechobee, FL
12/12/2021 5:11am
Hey guys currently in the middle of a build on my 07' rm125, I've recently gotten into the sport and only got a few rides on my bike before I had a failure. My question is should I get my suspension setup for me? it was setup for 160-170 pound rider by prev owner and I'm 112 pounds. Ill be riding almost entirely MX. I have already thrown a ton of money at this bike so setting up the suspension may make since. My only concern is that I may not be able to iron out the issues with a fresh setup as I have no experience? This is a question more for anyone in the South FL area, anyone have any opinions on Elliott at sharp moto? Haven't been able to find any reviews on him recently but he would be the closet suspension tuner to me. As his home track is the track I'm moving right next door to. Thanks
I would find out exactly what’s inside first before I decide.
I seen your thread where you had the engine apart, you can for sure handle suspension work. Pull the forks apart and find out the spring rates, shock spring is pretty simple to find out.
It’s nice seeing young guys working on bikes.
tel:941-322-8248
If anyone who knows spring rates could help that would be greatly appreciated. But I’d have to assume that’s a bit too much spring for 112 pounds. Edit: just went and used the race tech spring calculator and put in my weight, used b class (even though I’m definitely not b class lol) and used prefers stiff. It says to use a 4.08kg spring In the rear. That isn’t super far off as the spring thats in there is actually lighter then stock. Race tech says stock is 4.6kg. I may just replace oil to race tech’s level and try to dial in clickers. If I do replace fluid I’ll just have to clear out the space in the garage and check the springs. Stock front springs are .42. Would hope they would still be around that if the rear spring is that soft. Previous owner did say his suspension “worked best at 160-170 pounds” not that it was sprung for that. May be valved and sprung for much less weight and he just liked soft suspension.
Bark that thing and let us know how it goes.
242 SILVERADO ST
TAVARES, FL 32778
Post a reply to: Suspension help (South FL)
