Rebuilding an 08 RM125 for a friend, and on reassembly the final bolt I was putting in of the crankcases stripped the threads out of the case without even getting to tightening point. Are there any self tapping type screws/bolts that would suffice or do I have to strip it all down again and see if there's enough material for a proper thread repair?
Hopefully someone can point me in the right direction of a good quality easy fix.
In that case, best bet might be to weld/drill/tap. In either case, you're taking everything back apart.
Post a reply to: Stripped threads in engine case
