Harker heights, TX
What should I do to store by fc450 for a year? I initially thought to drain everything, but a quick google search mentioned to never drain anything when “winter storing” your bike. Wont the gas clog up and be bad after a year? I’m guessing leaving the oil and coolant should be ok. I was going to at least drain the gas.
My wife will be here and could start it every week or so, but she couldn’t ride it around. What do you guys think?
I live in Canada (originally from Houston though) and have been winterizing/summerizing boats, sleds, bikes, snowblowers, chainsaws, cars, etc most of my life. If you're concerned with the fuel degrading you could always syphon out the stabilized fuel and fill the tank with fresh gas when you go to fire it back up. Draining the complete fuel system on EFI is generally a lot of work (all my bikes are carbed fwiw) and any fuel left in the system will degrade faster as it has much more contact with air.
You’ll have to show her how to start it from cold so she doesn’t kill the battery as that will be the hardest part ,show her where to check the rads and just blips of the throttle throughout. Should only take a few minutes total depending how hot it is out.
Dont over complicate it. Dirtbikes dont expire like strawberries.
The bike will be fine, especially with starting it every 2-3 weeks. Just drain the gas/oil and put in fresh stuff before your first ride.
Keep the bike on a stand, not on the ground.
Post a reply to: Storing my bike for a year - what should I do?
