Las Vegas, NV
On my 2019 KTM the steering stem nut is completely tight but the headset is very loose. For example when I am pushing my bike and grab the front brake there is a lot of play inside the headset. I have already replaced the bearings and it still didn’t fix the problem. Can anyone tell me why? Thanks!
Maybe you need a spacer? The nut might be bottoming out on the stem?
Are you sure it’s the bearings that are loose? Not play in the brake pads or floating rotor?
Post a reply to: Steering stem problems...
