Softening suspension for TnT kxf450
6/8/2018 1:22 AM
Hi guys , I’ve softened the compression clickers off as I’m doing track and trail, my question is what should I do with the rebound on the forks and shock, should I soften that right off as well ? if not what should I be doing with it ?
Cheers Lee
6/8/2018 1:54 AM
lowering compression damping means you want to speed up the rebound. Otherwise you can experience some packing issues
6/8/2018 2:20 AM
Edited Date/Time: 6/8/2018 2:33 AM
Ok thanks , I must say the forks seem a bit lifeless, I’ll add some rebound , cheers
Edit have returned rebound clickers to stock , 13 out front , 10 out rear , see how I get in from here
6/8/2018 4:10 AM
Keefer did a podcast on suspension settings. He said something like 2 clicks out on compression = 1 click in on rebound - or something like that. The numbers are different for each brand of forks too. Give that a listen. Tons of good info.
6/8/2018 4:16 AM
Edited Date/Time: 6/8/2018 4:20 AM
Ok thanks will do !
Do you have a link to it ?
6/8/2018 4:26 AM
Its on the pulpmx app
