Smoke coming from hole in front right side of motor
6/5/2018 1:13 PM
when i fire up my 2005 suzuki rmz 250 4 stroke it leaks oil hitting the exhaust and i’m not sure where it’s coming from. also when it’s running there’s a hole that’s supposed to be there but not sure what it is that rolls out white smoke? any ideas on what the holes for and how to fix it?
6/5/2018 2:32 PM
Can you post pics of the holes youre talking about? Or say what the holes are on? Usually theres a weep hole on the right side of the cylinder to drain oil from the spark plug hole. Theres also a weep hole on the waterpump to indicate a leak of coolant or oil.
6/5/2018 3:56 PM
6/5/2018 3:58 PM
6/5/2018 5:22 PM
Edited Date/Time: 6/5/2018 5:23 PM
Thanks. That hole should be covered by a small plate and a bolt. It goes righf inside your cylinder head. The plate keeps oil out. The reason its there is because thats where the manual decompression cable would have gone back in the day.
6/5/2018 6:42 PM
X2
6/6/2018 5:38 PM
thank you , i just ordered it from rick roush . is there a difference from the plate then a rubber plug because that’s what i bought was the rubber plug the guy didn’t say anything about a plate.
6/7/2018 2:05 AM
Yeah theres a plug, plate, and bolt. See below. Photo
