Anyone used the kit for the airspring rebuild, and does it help reduce stiction.
Also I used a really slippery oil and slickoleum grease in the rebuild of my fox36 mountain bike forks, the difference was very noticeable in small fast frequency bumps. Does WP specify any specific oils and grease that could be substituted for a better product?
Even mixing some Slicko and and EP grease together could make things more slippery?
Have you seen or used the inntek SKF Piston seals?
Also what service intervals do recommend on the air spring?
Sorry for the load of Q’s.
Starting to love these forks finally..
You need the cap tools - spanner and nut thing to remove base valve (ebay), a heat gun (butane or something to melt the locktight and block of wood with 12mm hole to use as a shaft clamp, 2L 5w oil.
- drain air from air leg
- loosen base valve slightly (via nut tool and spanner)
- loosen top triple clamp bolts
- loosen inner carts slightly (using spanner)
- remove the forks,
- remove the carts from each tube
- drain outer oil and set aside,
- remove base valves,
- drain oil from inner cart,
- remove damping rods,
- remove the little clip that retains the plastic bottom out bumper,
- remove the plastic bit,
- install the cap tool in a vice, install inner cart facing up, heat the lower seal area, unscrew the seal head,
- install SKF seal head (assemble it first)
- reinstall damping side inner tube, fill with oil and bleed air out by cycling the rod
- Install base valve and bleed excess out (fiully bottom the rod with hole facing up)
- install damping cart back in outer tubes, add 220ml of oil and install back on bike
- put air inner tube in wooded block and do up tight in vice
- remove piston seal wear ring and seal
- heat piston thread area and remove
- install SKF seal head (red locktight)
- repeat assembly as per damping leg except before putting air leg back in outer carts I like to fill with air and check for leaks around the seal head and top cap.
I was going to order one of these to update the 17 cartridge I have in the xplors to '18 seals and everything.
https://www.ebay.com.au/itm/For-KTM-350SX-F-450SX-F-250XC-300XC-250XC-F…
Spanner
https://www.ebay.com.au/itm/50mm-WP-Dual-Chamber-Fork-Cap-Wrench-For-KT…
Rod holding tool
https://www.ebay.com.au/itm/NiceCNC-Rear-Shaft-Holding-Tool-Shock-Shaft…
But it's cool you've gone the whole hog and coated the internals!
Post a reply to: Skf low friction kit for WP Aer
