Ogden, UT
2460th
I have an old Honda Trail 90 or CT 90 and the shift pattern is opposite of standard bikes now, as in, neutral is all the way up, then each gear is down. Technically if you use the shifter as intended by Honda to shift up you press down in front and to shift down you press down in the rear.
Anyways, I would like to shift like a normal person again if possible, does anything exists that would somehow reverse the rotation of the shift lever outside of the engine?
Post a reply to: Shift lever reverser, anybody know if that exists?
