Going to be installing a factory connection Link. Its 2mm longer then stock. Should end up lowering the rear end just a bit. I pushed the forks up 5mm up in the clamps. I usually run around 106mm of sag. Any clue what I should set my sag to after I install the link? Should I lighten up the compression a few clicks since the initial stroke will be stiffer? Trying to get a solid baseline before I go and ride. Suspension is all stock. 190lb vet rider.
