Austin, TX
I used RaceTech’s spring calculator to figure out I should have .44 fork springs and a 4.3 kg shock spring at 140 pounds with no gear. I’m a C-class motocross rider on a KTM 350sx-f.
I just changed the spring and greased the linkage and all that. When I went to set the sag, the preload collar is all the way loose and I’m only getting 91mm of race sag. A local suspension tuner told me based on that information, a 4.3 kg shock should be correct.
Any ideas why I’m not able to get the correct sag? I sat near the front of the bike when measuring which is where I would say I am a good portion of the time riding. Maybe I should sit more towards the middle? Or is there something else it could be?
Does that sound out of order? A 4.3 kg shock spring for a 140lb C-level Moto rider?
My suspension tuner test each and every spring he works on, as he has found a fair amount that are not what is claimed on the spring. Sometimes two rates different.
I bought a FC spring. Are there any companies that are generally more accurate than others with their rates?
I didn’t include a free sag number because I was unable to get the correct race sag even with the preload collar backed all the way out.
I figured I may be measuring it wrong but I’ve watched 3 different videos just to make sure and I don’t think that’s the case. Should I sit more towards the middle of the bike to measure? I was sitting more towards the front since I feel like I’m up front the most.
The spring you have is just too stiff for you. I have also found some errors in the Race Tech spring calculator over time. I know my Husky showed as rate even higher than what I had and it was too stiff. I went to another company to get the correct spring.
Call Race Tech and speak with a tech for his opinion.
When you do your race sag....Wear all your gear and sit the middle of the bike. After you get this set where you want it, check your static sag to make sure it falls within range.
Post a reply to: Sag and correct spring rate
