I rode a maize field track today and with the weather we've been having recently it ended up very rutty through the turns and also running a good bit on the exit. It's the first time I've rode this bike in such rutty conditions and man did I struggle. The front end was constantly climbing out of the ruts, especially when trying to get on the power exiting. Anybody with a bit of suspension knowledge know what adjustments I need to be making? I ride a 16 crf 450 with ohlins cartridges in the forks.
Do what Paw Paw said.first though.
If your have ohlins inserts it sounds like you are not a beginner. I think we all struggle with ruts at some point. Here are a few things u can try/work on.
-Weight the outside peg on ball of foot.. This is huge for me!! It really makes a diff
-Look ahead. If you stare right in front of the wheel you will always have trouble
-Let the bike lean. Try not to fight the bike. Let it settle
-drag the front brake Gently. I commonly do this. Especially helps while under power, helps keep the wheel planted.
-keep your butt forward. Sitting to far back will make the front end light feeling and more prone poping out.
I maybe could afford to go a couple of clicks out the compression too, especially round that track as it's just a turn track. If that doesn't help I'm guessing I'll have nothing else to blame but myself
Thanks again!
Edit: right bar bend will get you further and more front end weight.
Also, dont be afraid to run less sag on a rutted course, like 100mm.
On forks, you could also raise them slightly in the trees. Maybe 2mm to start with the sag you have. Enjoy!
Post a reply to: Rutted corners/suspension advice
