- Pick trends
- Create a private league
- And more!
Electrical tape, about 4 wraps, not too tightly.
One down the middle, then one offset slightly to each side, then down the middle again.
Also open the holes with a phillips screwdriver, rotating against corner of hole to cut the tape clean.
I like to use Honda style rubber grommets on valve stem to keep debris out
i check each wheel set for any burrs on the nips than run a rubber band like stock, never an issue.
Post a reply to: Rim tape or rubber?
