86oh, CT
torn between what to do.
My 17 yz450f needs to have the front fork seals done. Bike only has 25 hours but the right side started slowly leaking about a month ago. I tried cleaning the oil seal, it helped but it still leaves to the lower fork tubes wet with oil after compressing the forks.
Anyway. I called Factory Connection. and got a quote to refresh my front forks. This included new seals, oil and bushings. I have had them re valve 2 other bikes and have always had good results. While getting the price quote asked how much extra to do a re valve while they were in there. It would only cost me an extra $140 to do there revalve service. Due to the factory springs being proper for my weight and ability it helps reduce the cost.
To keep cost down does it make sense to just re valve the front and leave the rear stock considering I have the correct spring rates? Will I see a real benefit having the front done?
For my 09 kx450 kyb suspension, i noticed my forks softening at about 15 hours due to breakdown.
Post a reply to: Revalving front forks only? leaving rear stock?
