Watkins Glen, NY
This stuff is getting harder to find and is a bit pricey. I'm not up on all the tech and nerdy stuff on fork oil and was wondering if there are cheaper, more available options? I've always been told that that even though the FF5 is a 5 weight, it's somehow different. What about if I don't change the inner chamber oil, will it be ok to mix? Everything is closed today so I thought I'd ask here.
I've had great luck with Maxima and Bel-Ray (it's all I've tried, I am sure many others are excellent, too). They seem much better than OEM ad far as longevity.
https://www.rockymountainatvmc.com/parts/golden-spectro-cartridge-fork-fluid-p
That would also mean that the inner chamber would then be "over-filled" for some period of time until the excess was forced out the top past the base valve assembly and into the chamber space at the top where the compression spring resides.. at least until it worked it's way out the weep holes and back into the outer chamber. It sounds like we're talking a very small amount here, but this would mean that the volumes of oil in both the inner and outer chambers are not static or consistent on every stroke of the fork. The fork would not respond the same on every impact. Does this migration of oil occur on every bottoming of the fork? Or only on extreme hits in rare cases?
If this is true, this is the first time I've ever heard that the inner "Sealed chamber" is not really a sealed chamber. Can anyone else confirm this or explain this more fully? Is there somewhere I can read about this and understand it better?
Post a reply to: Replacement for Factory Connection FF5 fork fluid?
