Removing stain from clutch cover
2/20/2018 8:07 PM
So i have this stain on my clutch cover. I’m not exactly sure what it is but i can’t seem to get it off. Looks like over spray of some sort. So far I’ve tried: MR clean, simple green, carb cleaner, brake cleaner, and rubbing compound. Nothing has touched it yet. Any other ideas?Photo
2/21/2018 1:26 AM
Whatever it was probably messed up the finish on it. If those didnt work to clean it idk how youd get it off. Abrasives or paint thinner will f up the finish even more.
2/21/2018 1:35 AM
Yeah you definitely got something that was acid based on it and it attacked the akadizing on that cover.
When my 2013 YZ450F was brand new I had probably 3 grand worth of aftermarket stuff on it, Hammerhead, Yoshimura GYT-R, Ride Engineering, Works connection... Went for a ride at the in laws farm and decided to wash it while I was there, he had this car wash that I thought was the same as I usually use, sprayed it on left it be for 5 minutes and pressure washed it off along with all the colour from every single anodised and painted part on the bike, it even etched the bare aluminium frame dark grey. I wish I had photos to show you, looked exactly as your clutch cover does.
Instagram @_yabba_dabba_dont_
2/21/2018 4:01 AM
WD-40, 5-56 or similar may at least temporarily make it look better.
