Carbondale, PA
9/11/2022 6:57pm
Hey guys, I have a set of WP forks that were anadized black that I recently just bought. I would like to remove the anadize as they’re kinda worn/shitty looking. If I remove the anadize/coating what will I be left with? What are my options ? Thanks
Best options:
1. Trade with someone that wants black forks
2. Touch-up the scratches with THIS
3. Sell them and buy a different set
Generally, the answer is no. You need the anodize surface for wear resistance and friction reduction on the inside of the tube.
The right way to do it is to have it professionally stripped (slowly, otherwise it will pit), then re-(hard)anodized. Typically around $250 for that service, or more if you want something fancy.
You can also mask the inside, strip the outside, then re-anodize. That's a little easier to maintain the important inner surface, assuming it's still good inside. Regardless, it's not something you can correctly do at home.
Post a reply to: Removing anadize from upper forks that were coated
