MOTO, IL
12/12/2016 10:06am
Clearly I'm not the worlds most knowledgeable mechanic....someone please inform me how to get the bearings out of the rear hub??? Front was easy, pop the seals out and drive the bearings out from side opposite...no issues. This rear hub on the other hand is being a bit troublesome for me.
According to the parts fiche, there is a lock ring between the seal and the bearing on the rotor side of the hub...is this correct? Does that mean for some reason the sprocket side bearing needs to come out first? I can't even seem to get the seals out in order to gain access to the lock ring...these seals seem to be metal? I guess I'm just a bit challenged on this one...someone please provide me some insight
Post a reply to: Remove Husky/KTM Rear Wheel Bearings - Help
