Chester, IL
Picked up an on Suzuki TS250 to part out. Flywheel has the 3 threaded holes each about 120 degrees apart for removal use. So newer style puller (which I own about 6-8) isn't going to work.
So I need the old style slider type or something with the plate with 3 holes for the bolts to go thru & the one in the middle to push against the end of the crankshaft. Hope this make sense.
Anyway, what are you guys who work on old stuff using?
I just knew there was some other name for what I needed, but having never removed a steering wheel or harmonic balancer, it was probably never going to come to me!
Post a reply to: Recommend Old Style Flywheel Puller
