Lynnwood, WA
Not the first time that I have done them, but certainly the first time that I have had this problem.
I installed ned bearings today, was careful not to smack them, used a socket to seat them as well know to do, etc. I am 99.9% sure that I got them completely seated into the hub but now they are binding when I put an axle in. All 3 roll perfectly but the axle will not go through smoothly, it doesn't really want to go through at all, and is a bitch to get back out.
Its acting like at least one of the 3 bearings didn't seat properly. any suggestions on how to troubleshoot this?
Smack them to seat
I beat the shit out of both sides a bit more and it got slightly easier. I have two spare bearings. I may beat the rotor (single bearing side) out and try a new one. its the side that feels like it is binding.
Are you applying a thin coat of grease to the axle before you install it?
For whatever reason the inner surface in the bearing wasn’t a good finish and forced the axle just enough to bind it. The markings were very clear in the polished finish of the axle.
Rolls like a dream now!
Post a reply to: Rear Wheel Bearings
