RMZ450 easier kick lever
4/23/2018 11:28 PM
Having bad knees makes it hard bending them enough to get a good kick from the top of the stroke as the lever sits so high. l hate having to look for a rock to stand on if l stall out on the track. l was looking for a shorter lever; it's easy to turn the engine over with the standard decompressor (compared to my CR500 :-) ) so a shorter lever will not be a problem in that area.
No one makes a shorter lever but l made one; l used the upper alloy lever from the '07 to '10 RMZ250, this mounted perfectly to the steel boss of the 450. lt did slightly foul with the stock header-pipe heat-shield (on the 2011 model); l didn't want to trim the stock heat-shield so l made a new one; l bought a alloy strip from the local hardware that is used on the edge of carpet in doorways, cost me $9 and have enough to make 5 sheilds, it's lighter & stronger than the stocker.
The kick arm sits about 1" lower, much easier to kick :-)
Melbourne, Australia. Current rides: '11 RMZ450, '84 CR500, '06 DRZ400, '79 KX250 with 400 engine, '06 GSXR1000 full Yosh racebike.
