Salamanca, NY
DerickYZ
1/13/2018 5:09am
1/13/2018 5:09am
I'm looking to upgrade my 2016 RMZ250's suspension. I have a killer deal on some new suspension but it is off of a 2016 RMZ450. My question is, will the forks and shock swap with no issues? I would just hate to buy this suspension then have it not fit.
With regards to the forks you will need to compare fork diameters. The 250 and 450 use the same front wheel/axle/spacers etc so you shouldn't have any issue there. Of the top of my head the 16 RMZ450 SFF TAC fork measures 55.5mm at the upper clamp and 59.5mm at the lower clamp. But I can confirm this later.
What suspension are you getting from the 450? Is it stock? Modified or standard?
Post a reply to: RMZ Suspension Swap?
