Union Bridge, MD
m1ke20012
6/19/2020 2:53am
6/19/2020 2:53am
Hi, I have a 99' RM80 which I assembled the clutch and cover on perfectly the first time and went for a full day of riding. Decide to change the trans fluid and replace the raggedy clutch cover gasket and now ever since the clutch has refused to work correctly. It at first pulled really hard when I test rode it and then I lost all clutch. Took it back apart and after reassembling again it pulls so hard I can see the holder on the case for the clutch cable bending.
If you're familiar with RM80/85 they use a pinion design to pull the pressure plate out, if that helps. New clutch cover assembly and clutch cable otw.
Post a reply to: RM80 Hard Clutch Pull/Problems
