Manchester, NH
8/17/2021 3:32pm
Recently purchased these forks and rear shock for my 2007 RM250 and not entirely sure what I have here. They were advertised as rebuilt by RG3 and came off a 2004 RM250.
I took the forks apart to inspect the internals, check the bushings and replaced the oil in both chambers. I'm pretty green with suspension tear downs but didn't see any unusual wear. Also installed the forks and shock on my bike and everything works/fits as it should.
Couple observations:
-The lower fork tubes are 48mm and DLC coated. (47mm is standard?)
-Shock shaft is DLC coated and 16mm. (2005+ RMs are 18mm)
-Red anodized upper chamber but doesn't have any manufacturer or p/n stamped.
-Upper fork tube looks more like a WP tube. Doesn't have the groove for the wear ring BUT has a groove higher up (for a holeshot device?)
Any ideas what I have here or can anyone point me in the right direction for spare parts?
Thanks
Thanks
In 05, they went to the bigger cartridge showas with a larger piston and 19mm across the flats base valve that was recessed into the fork cap.
All were 47mm fork tubes.
I can't remember, but maybe the crf450 showas around that time had similar anodizing on the cartridge?
Did some re-measuring of the lower fork tubes and consistently getting 47.7mm with a few spots near 48mm.
Any upgrades you would recommend for this set? I do have the stock 07 RM250 forks/shock that was rebuilt by FC a few years ago and valved for woods riding. Would like to keep this "new" set for MX.
Also, to my knowledge all Honda stuff was anodized brown/bronze (possibly Kashima?) for the outer cap/cartridge top.
Post a reply to: RM250 Showa RG3 Forks and Shock?
