Time to change the chain... Stock chain on my KTM was Regina GPXV and lasted 110 hours so I thought buying it again but I see now that DID ERT2 is half the price and supposedly also a very good chain.
What are your thoughts?
Edited Date/Time:
I literally just bought a chain/sprockets last night and it's the first time in years I didn't buy a DID ert2, those chains are great. I don't have much experience with Regina other than my stock KTM setups.
I got 26 hours on my stock 250sx chain/sprockets and the rear was basically about to shed teeth.
The last ERT2 chains I bought didn't last long at all. They now have replaced it with an ERT3, so I'll have to try another one. I will say that you will NOT get 100+ hours out of a non-sealed chain.
100 hours on a chain holy shit that’s a first for me to hear, I’m lucky to get 30 hours out of one lol, I don’t push it on them either and I don’t run oring chains but still dang.
I have been running the RK gbmxu sealed oring chain on all my bikes.for about 5 years now...it is very thin so it fits MX bikes no problem, after initial stretch it does not stretch much after. Much quieter than non oring. I get about 25-30 hrs On my 450, a little longer on smaller bikes.
Is it a good idea leaving a link more in the chain and moving the real wheel further back? I have a 48 spring and weigh 190 pounds....thinking I will soften the rear with this. Will the handling be much worse with longer wheel base?
On my KTM I like running the wheel farther back. I like the stability it adds.
On a 09 yz250f i had i had to keep the wheel forward. If it was adjusted half way or more back id lose the front end randomly in corners. That change really blew my mijd as i normally cant feel stuff like that but was a big difference.
If a stock husky chain is Regina, then that’s the only time I’ve run one, and I only got 16 hours out of it. I used to always run did ert’s but switched to Rk mxz4 and they last longer. Keep your chains adjusted , clean and lubed and it prolongs chain/sprocket life quite a bit.
