Dallas, TX
Hello, first post here. I have an 02 cr250r and need to replace the servo motor for the RC valve. Is this the appropriate motor?
Mabuchi RS-365SH 2080
MODEL VOLTAGE
RS-365SH 2080 6 - 20 18 19400 0.25 15910 1.14 7.66 78.1 12.7 42.6 434 5.20
Applications
Home AppliancesMassager, Vibrator
MODEL VOLTAGE
Applications
You'll probably be able to swap a CBR600RR servo motor into your RC motor case while reusing your plastic gearing. Older CBR servo motors might swap easier. Some minor wiring changes may be necessary. Here's one for $5 bucks delivered.
Honda uses Sumitoto HM electrical connectors which look like the one on this CBR unit. You may even be able to use that, again with some minor rewiring.
If saving money is not a priority, then brand new servo motors are still available for purchase from Honda. Be sure to seal the wiring bundle better where it enters the case as water can seep in and cause internal corrosion.
Post a reply to: RC motor confirmation
